Activity › Forums › Adobe After Effects › combining AE and Flash?
Posted by Jimmie on November 20, 2005 at 4:39 pmAny advice on how to combine AE Pro and Flash MX?
I don’t think I’ve ever seen any examples of the combination.
thanks
Kelly Johnson replied 20 years, 10 months ago 4 Members · 5 Replies -
Mike James
November 20, 2005 at 6:25 pmSomeone had a good link to a tutorial about this. It might have even been a cow tutorial. I’ll dig around and see if I can find that link because it was sooooo detailed.
FYI, Adobe originally said that the new video collection (which includes After Effects) will release in the 4th Quarter. Which means that AE7 which has a seamless export to Flash (with alpha channels) is right around the corner.
But for now I’ll hunt for that link.
Mike James
VFXpodcast.com -
Kathlyn Lindeboom
November 21, 2005 at 3:04 amHere’s the link to our AE-Flash tutorial:
https://creativecalf.creativecow.net/cgi-bin/new_page_wrapper.cgi?forumid=2&page=https://www.creativecow.net/articles/brimelow_lee/ae4flash1/index.htmlThis tutorial demonstrates animating text in AE exporting it to Flash. Hope it helps.
Kathlyn Lindeboom
The Mistress of Mmmooooo! -
Jimmie
November 21, 2005 at 4:08 amyeah, I’ve seen that tutorial already. Thanks anyway.
I am hoping for a tutorial going the other way, from Flash to AE.
Take my Flash movie into AE Pro, and add some effects.
Kelly Johnson
November 21, 2005 at 11:51 pmWell, you can import swf files and quicktime movies into AE which you can create out of FlashMX.
I did this for a tradeshow website. I created a presentation in Flash which linked to a movie. Then, within that movie I had imported a separate swf file and put that in an AE composition which I rendered out as a quicktime movie that was then exported as an flv file out of AE. That flv was put inside a separate flash file and was called from the first.
Just keep the framerate the same between the two. You can export a quicktime movie or w
