Activity › Forums › Compression Techniques › Combining a Premiere Pro and Final Cut Pro Project
  • Combining a Premiere Pro and Final Cut Pro Project
    Posted by Travis Roesler on February 22, 2014 at 6:00 pm
    Hey guys…
    I edited some stuff a while ago and I’ve decided to replace some of the footage in the clips…. unfortunately I edited this in premiere pro.
    I’m trying to figure out a workflow that will allow me to combine the work from these very different codecs.
    I’m editing the Premiere Pro stuff as it’s native AVCHD codec, HD 1080p using a Sony FS100.. the Final Cut stuff obvioulsy is in ProRes.
    I have failed every time I’ve tried to turn my 1080p footage into prores using Adobe Media Encoder. In fact, I can’t even find a setting that allows me to export in 1080p… only 1080i into prores. This comes out looking crappy.
    I suppose the best alternative would be to convert the prores stuff into a good codec to combine with premiere’s stuff.
    Do you guys have any suggestions?
    FCP7
    PP 6.0.5
    ame whatever the most recent version is (from cs6)
    —Trav
    Craig Seeman replied 12 years, 7 months ago 2 Members · 1 Reply
  • Craig Seeman
    February 24, 2014 at 11:23 pm
    [Travis Roesler] “I suppose the best alternative would be to convert the prores stuff into a good codec to combine with premiere’s stuff. “
    Current NLEs PremierePro CC and FCPX can both handle multiple codecs in a timeline. If you have AVCHD sources I’d convert those to ProRes rather than throwing away information by compression ProRes files.
