Activity Forums VEGAS Pro Combing or copy/paste projects
  • Combing or copy/paste projects
    Posted by Paul Gregory on February 17, 2012 at 6:46 am
    It must be quite a time since I used some features because I don’t seem to be able to do some things as I recall. I seem to recall doing a copy & paste between projects by doing a CTRL A copy of first timeline & then doing a paste onto a new timeline. When I try this now I notice that the chapter markers aren’t copied. Did I do something wrong or have things changed? I’m using Vegas 10.
    The other thing that I recall is having a project on the timeline & then click open & being able to drag another veg file onto the timeline & have it open where I wanted it. Is there some setting that I missed?
    Any help would be apprecieated.
    Thanks in advance
    Paul Gregory replied 14 years, 6 months ago 3 Members · 4 Replies
  • Andy Hart
    February 17, 2012 at 9:58 pm
    Chapter markers aren’t copied. Render it out in a format that supports markers and won’t degrade your video and drag it into the new timeline. Click Tools > Scripting > Promote Media Markers. You can also drag the old .veg project file (from the same version of Vegas) into a new project’s timeline… but Vegas will want to render it once you do this.
  • Paul Gregory
    February 19, 2012 at 4:07 am
    I would have liked to be able to just drag an another veg files onto the timeline immedieately after the end of the current project. I go to file>open tab select another veg file & drag it onto the timeline but nothing happens. Is there some special tecnique for doing this?
    Thanks in advance
  • Mike Kujbida
    February 19, 2012 at 12:33 pm
    You need to import the veg file into an existing project.
  • Paul Gregory
    February 20, 2012 at 12:22 am
    I’m doing file>import>media & then selecting a veg file & click open. One or the other of 2 things happens. The little twirling circle goes for a few seconds & stops or I see that the the program is builing peaks. In either case nothing happenns to the timeline. Only the original timeline data appears.
    Maybe I should just do a reinstall of the program since I’m also having a display problem as well inasmuch as if I have have the cursor at the end of the timeline & double click the preview window disapears.
    Thanks in advance
