Activity › Forums › Adobe Premiere Pro › Combing Issue with mixed footage
  • Combing Issue with mixed footage
    Posted by Aryn Leigh on March 22, 2016 at 9:32 pm
    Hi all-
    Hopefully this is a quick fix. We shot some action footage last week with two C100’s, using a Ninja to convert to ProRes 422. One, a Mark ii, was improperly set to record in 1080i, which we discovered during import. (whoops!)
    When we render out the mixed footage on the timeline, we get a big fat combing effect on the interlaced shots- even when I try and interpret the footage to progressive (both in the project window and in the timeline.)
    Here are our Premiere CC settings:
    Editing Mode: DSLR
    Frame Rate 29.97
    Size: 1920×1080/ Square pixels
    We are on a late 2013 iMac using El Capitan, if that is useful.
    Thanks in advance for any advice!
    Aryn Leigh replied 10 years, 6 months ago 2 Members · 2 Replies
  • Pierpaolo Ferlaino
    March 23, 2016 at 9:55 am
    You should keep your footage interpretation (project window) as native… If premiere is misinterpreting the native field scan set it manually to interlaced (upper field)… Then edit in a progressive sequence…
  • Aryn Leigh
    March 23, 2016 at 4:49 pm
    Wow, that worked like a charm! Thank you! 😀
