Activity Forums Adobe After Effects combine two projects…???
  • combine two projects…???
    Posted by Mohit Woody on September 26, 2006 at 8:22 pm
    hey there… i am trying to use 2 seperate *aep files.. i mean i hv 2 seperate compositions in 2 seperate file.. wanna merge them.. cant do it..
    tried copying comp to clipboard.. but no go..
    pls adivse..
    thanks.
    Raj Vivan replied 13 years, 9 months ago 5 Members · 6 Replies
  • Greg Neumayer
    September 26, 2006 at 8:36 pm
    Often if I have two projects that both need to render that night, I’ll create a third AE project and just import my other two into it. When you import an AE project, it brings everything, including the render queue, which makes it handy for creating a batch render of multiple projects.
    -Greg
    Antifreeze Design
    https://www.antifreezemotiongraphics.com
  • Colin Braley
    Just goto file > import and select the .aep with the comp that you want. You will then have the whole second .aep in your current project.
    ~Colin
  • Colin Braley
    September 26, 2006 at 8:38 pm
    Apparently I’m 15 seconds too slow 🙁
  • Mohit Woody
    September 26, 2006 at 8:50 pm
    gotchya..
    thanks a lot…
  • Mehmet Yufka
    January 19, 2012 at 1:04 pm
    i ve same problem here, i ve 2 seperate .aep files and i need some comp that in file 1… how can i merge compositions in to a my other project file???
  • Raj Vivan
    November 7, 2012 at 12:02 pm
    i am also acing the same problem
