Activity Forums VEGAS Pro combine tracks for transition?
  • combine tracks for transition?
    Posted by Gilles Gagnon on June 9, 2012 at 12:32 pm
    Good day Cowsters,
    I have events in several tracks layered as composite. I want to collectively use this “set” and use a transition (ie. wipe) to another event.
    Can this be done without having to create a nested project?
    Gilles
    Tyson Onaga replied 14 years, 3 months ago 4 Members · 6 Replies
  • Jeff Schroeder
    June 9, 2012 at 2:22 pm
    Only with ‘render to new track’ which is quite like a nested project.
    Jeff
    2-Xeon X5680 @ 3.33, EVGA SR-2 Mobo, 48GB DDR3, GTX 580 3072MB, 16TB Attached Storage, Win7, Vegas 11 x64
  • Gilles Gagnon
    June 9, 2012 at 2:27 pm
    Thanks Jeff,
    I guess I’ll stick to the nested approach. I think it may be a cleaner approach.
    I had completely forgot the “render to new track” function. Thanks for brining it up. not sure when I ‘ll use it but good to have in my toolkit.
    Gilles
    Gilles
  • Aleksey Tarasov
    June 9, 2012 at 2:52 pm
    > “Can this be done without having to create a nested project?”
    No. But you can try the following: Take a snapshot of your “set” and use it for a transition 🙂
    Vegasaur – automation plugins and tools for Sony Vegas Pro
  • Gilles Gagnon
    June 9, 2012 at 3:11 pm
    Another clever trick 🙂
    However, there is motion in the set so I can’t use it in this case.
    Thanks, Aleksey
    G
    Gilles
  • Jeff Schroeder
    June 9, 2012 at 4:09 pm
    I would set a region for the transition, select it, and render to new track (selection only). This speeds up your final render because nesting seems to take so much more time.
    Jeff
  • Tyson Onaga
    June 9, 2012 at 9:35 pm
    If you have multiple tracks, maybe something like:
    Track C:__ Parent
    Track D:____ Child
    Track E:____ Child
    Perhaps something like this:
    Track A:__ your “next” event
    Track B:__ Parent (Sony Solid Color, White), Multiply (Mask)
    Track C:____ Parent
    Track D:______ Child
    Track E:______ Child
    The Sony Solid White should be the exact length of C, D, E (whichever is longest). Make sure the compositing mode is Multiply(Mask).
    The events in Track A and B overlap, where the Transition will be applied.
    Add a fade out to the event in track B.
    Add a fade in to the event in track A.
    These two fades should be the same length.
    Apply the same Transition to the fades in the events in tracks A and B.
