Activity › Forums › Apple Motion › Combine Splines and add moving path
  • Combine Splines and add moving path
    Posted by Peter Silie on October 31, 2016 at 5:16 pm
    Sorry, if I use strange descriptions, but I’m using the german version and have to guess what this is called in english.
    I want to animate a small car driving along my tour. First I created a very long path (as a spline). Firts this worked fine. But it produced some severe problems, when I was not able to add further points. So my new approach is to create several parts of the tour, group them and use this complete one for animating the car. But I don’t get it handled as one single spline. The group does not get the optiony nor settings a spline offers. Do I have to assign the graphics of the car to each spline in the group again and again?
    Is there an option to join the many splines to a new single one? In this case I can edit the smaller parts and then join them to be used by the animation.
    Peter Silie replied 9 years, 10 months ago 2 Members · 2 Replies
  • Mark Spencer
    November 8, 2016 at 2:26 pm
    You can’t join splines together but you should certainly be able to add more points to an existing spline by Option-clicking on it. You might want to take a look at this: https://www.youtube.com/watch?v=FIm7qOvPlCQ
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Peter Silie
    November 8, 2016 at 7:02 pm
    Yes, in most cases I could add. But in this case it seems to be damaged internally. So when I try to add a point it is placed somewhere else and far away from the mouse position. Even rebooting didn’t solve that problem. Maybe to much points in one spline??
