Activity › Forums › Adobe Premiere Pro › combine left and right audio ch. on L & R audio
  • combine left and right audio ch. on L & R audio
    Posted by Bob Ali on May 10, 2005 at 11:21 pm
    When shooting live stage show i have a line audio feed to the right audio ch. On the left audio ch. i record ambient sound.
    How can i combine the L&R audio ch back in post. (i am still using 6.1)
    I am trying to lave both feeds on the left & Right audio tracks.
    Thanks in a advance,
    Bob
    Mads Nybo jørgensen replied 2 years, 4 months ago 4 Members · 3 Replies
  • Scott
    May 12, 2005 at 7:02 am
    Hi Bob,
    I would duplicate the audio track into audio 2. Then I would choose “Fill Left” for the original and “Fill Right” for the copy. This way audio track 1 represents only what’s in the left channel, and audio 2 represents the “right” channel sound. Now the volume levels of each individual source can be controlled, have seperate effects applied and panned in the stereo (mono in this case) field.
    Scott
  • Dmytro Kirkov
    May 13, 2024 at 3:08 pm
    Simply use “Channel Mixer” effect.
    In effect controls press edit,
    choose left channel and set both L & R to 100%
    than choose Right channel and set both L & R to 100%
    If you have ambient sound in one channel you can set it to any vavue from 0 to 100% to controll the loudness
    May 14, 2024 at 12:13 am
    I normally double the tracks and pop on a audio effect “fill left with right” in one track, and “fill right with left” on the other track.
