Activity Forums Adobe After Effects Expressions Combine expressions for position and anchor point with text animator
  • Combine expressions for position and anchor point with text animator
    Posted by Christian Geijer on August 10, 2018 at 7:51 am
    I have a paragraph text connected to a .json-file for its value.
    Let’s say I want the text to be centered in the composition, so I enter this position expression.
    [thisComp.width/2, thisComp.height/2]
    The source text from the .json-file can differ in length so to make sure that the text remains centered no matter what is inputted I use this expression on the anchor point.
    boxTop = this.sourceRectAtTime().top;
    boxHeight = this.sourceRectAtTime().height;
    boxLeft = this.sourceRectAtTime().left;
    boxWidth = this.sourceRectAtTime().width;
    h = boxTop + boxHeight/2;
    w = boxLeft + boxWidth/2;
    [w, h];
    This works just as intended. But if I want to add an animator for the position – let’s say to animate each line one by one up 20 pixels – this doesn’t work because I’ve locked the anchor point with the expression above. If I remove this expression the animator works just fine. But then I can’t make sure that the text remains centered.
    My questions regarding this are:
    1) Is there a smarter/better way to make sure the text stays centered than using the combination of expressions above?
    2) If not, is there a way to combine the animator for the text and still make sure the text stays centered in the composition?
    Best regards,
    /C
    Christian Geijer replied 8 years, 1 month ago 2 Members · 2 Replies
  • Kalleheikki Kannisto
    August 11, 2018 at 7:59 am
    Pick a time before the text animation starts as the time value, as in sourceRectAtTime(*your static time value here*).
    Senior Graphic Designer
  • Christian Geijer
    August 13, 2018 at 6:50 am
    Of course! Thank you so much for your help.
    Have a great week!
    /C
