Activity › Forums › Adobe Illustrator › combine colors from an object into another
  • combine colors from an object into another
    Posted by Gabriel Ristea on November 12, 2013 at 9:35 am
    Hi guys and first of all sorry for my bad english.
    I am a beginner in illustrator and what I need tot do is:
    I have one object (with multiple color) and another object that I want to put colors from the firs
    This is the object that i want to color
    with this object
    can you tell me how to do this? 🙁
    Jonathan Ziegler replied 12 years, 10 months ago 2 Members · 3 Replies
  • Jonathan Ziegler
    November 13, 2013 at 2:18 pm
    Sounds like you are doing a clipping mask. Arrange your 2 objects (assuming both are vector objects) by positioning first the colored part how you want it, then put the paint daub above it. Select both objects, then go to Object >> Clipping Mask >> Make or Command-7 or CTRL-7.
    If they are not both vector objects, use Photoshop to combine them.
    Save early. Save often.
    Jonathan Ziegler
    http://www.electrictiger.com
    520-360-8293
  • Gabriel Ristea
    November 13, 2013 at 2:21 pm
    Thank you i will try. Pattern will be ok?
  • Jonathan Ziegler
    November 13, 2013 at 3:27 pm
    Well, try it and you can always UNDO.
    Jonathan Ziegler
    520-360-8293
