Activity › Forums › Adobe Premiere Pro › Combine Canon XA10 and 7D footage in Premiere PRO CS5
  • Combine Canon XA10 and 7D footage in Premiere PRO CS5
    Posted by Brad Shirakawa on February 11, 2012 at 6:30 pm
    I want to use footage from my Canon XA10 and Canon 7d in the same Premiere Pro CS5.5 project. Any recommended settings/preferences I should set first before importing the video into a project? Or recommended HD settings in each camera before shooting? Mucho many thanks in advance!
    Brad Shirakawa replied 14 years, 7 months ago 2 Members · 2 Replies
  • Ryan Holmes
    February 11, 2012 at 8:19 pm
    If you haven’t shot yet, then just make sure your frame size and frame match between each camera. That will save you some headaches before you get to post.
    If you want a 1080p30 project make sure both cameras are set to that. Or if you’re doing 1080p24 set both cameras to that. Be careful if choosing 24fps on the XA10 – 24p Progressive is actually recording a 60i format and using an algorithm to get to 24. If you chose Native 24p then you’ll be recording 24fps in a native (i.e. no interlacing or pulldown) format.
    https://en.wikipedia.org/wiki/24p#60i_to_24p_conversions
    Ryan Holmes
    http://www.ryanholmes.com
    vimeo.com/ryanholmes
  • Brad Shirakawa
    February 12, 2012 at 12:23 am
    Major thanks, Ryan!
