Activity Forums Blackmagic Design Fusion Combine 4 EXR files into a single Multichannel EXR
  • Combine 4 EXR files into a single Multichannel EXR
    Posted by Justin Imhoff on December 15, 2018 at 4:44 pm
    I’m trying to combine several Cryptomatte EXR files from V-Ray into a single, Multi-channel EXR file using Fusion9. I read somewhere you can do this the a channel boolean node but I have no idea how. Is anyone able to assist?
    Many thanks.
    JJ
    Justin Imhoff replied 7 years, 8 months ago 2 Members · 2 Replies
  • Simon Ubsdell
    December 16, 2018 at 11:11 am
    You need to go to the Aux Channels tab of the Channel Booleans tool and use the dropdown menus to select which foreground input to add to which background channel:
    Note that this tool only takes two input so you will need three instances if you are combining four inputs.
    Simon Ubsdell
    tokyo productions
    hawaiki
  • Justin Imhoff
    December 16, 2018 at 3:20 pm
    Thanks for the reply. I’m not sure which foreground input to put into which channel. I tried this way but it didn’t work.
