Activity Forums Adobe After Effects Expressions combine 2 expressions
  • combine 2 expressions
    Posted by Jonas Espinoza on August 11, 2010 at 8:54 pm
    so this is a combo of something i was asking about yesterday
    I am being asked to make the objects bounce up and down once when they change color using the 2nd expression below which is in the color parameter of a fill effect, referencing a marker on a null.
    the problem is I already have the objects dropping in with the drop script below. I wonder if there is a way to add a variable, that changes the y value in the drop script so that the objects reference a new slider animation with the same delay and timing they are being effected by on the color script?
    does that make sense?
    //drop script
    t=time-inPoint;
    N=thisComp.layer(“dropper”);
    dropper=thisComp.layer(“dropper”).effect(“drop”)(“Slider”).valueAtTime(N.inPoint+t);
    ***b= thisComp.layer(“dropper”).effect(“bounce”)(“Slider”).valueAtTime(N.inPoint+t);
    d=(value[1]-dropper)-b;
    [value[0],d,value[2]]
    *** i added this but started thinking, it should be similar to the color script
    //color script
    L= thisComp.layer(“marker null”);
    delay = thisComp.layer(“dropper”).effect(“color delay controller “)(“Slider”);
    result = value;
    if (L.marker.numKeys > 0) {
    t = L.marker.key(1).time;
    if (time >= t) {
    if(Math.floor((time-t)/delay) + 1>= index){
    result = [1,0,0,1];
    result
    Jonas Espinoza replied 16 years, 1 month ago 2 Members · 3 Replies
  • Jonas Espinoza
    August 11, 2010 at 9:21 pm
    this is what i’m trying – not exactly doing anything…
    t=time-inPoint;
    m_t=L.marker.key(1).time;
    b = thisComp.layer(“dropper”).effect(“bounce”)(“Slider”).valueAtTime(m_t+(index*delay));
    d=(value[1]-dropper)+b;
  • Dan Ebberts
    August 11, 2010 at 9:50 pm
    It’s tricky. Can’t you just add the bounce to the end of the original slider animation?
    Dan
  • Jonas Espinoza
    August 13, 2010 at 12:00 am
    thats what i did. somehow i got it to work. had to pull out a piece of paper and really think through what was happening in the expression.
