Activity › Forums › Adobe After Effects Expressions › Combinations / permutations on after effects
  • Combinations / permutations on after effects
    Posted by Gon Perdigao on November 13, 2012 at 12:04 pm
    Hi there,
    I’m struggling with a work that i have 3 position for 9 people that can only be in one position at a time for 10 seconds and them have to change for another one.
    So by my math is about 9*9(the position that each person can occupied each position)*3 (the number of position available) 243 possible combinations.
    Is there a script based on the index of the layer or the number of the footage to arrange a comp with this 243 possibles combinations?
    Dan Ebberts
    replied 13 years, 10 months ago
    2 Members · 3 Replies
  • Dan Ebberts
    November 13, 2012 at 2:21 pm
    I think there would be 504 permutations (9*8*7) and code like this should generate all of them:
    for (var i = 1; i <= 9; i++){
    for (var j = 1; j <= 9; j++){
    if (j == i) continue;
    for (var k = 1; k <= 9; k++){
    if ((k == i ) || (k == j)) continue;
    // do stuff
    The code to actually moves the footage into the comp is going to depend on how you have things organized.
    I hope that gets you started.
    Dan
  • Gon Perdigao
    November 13, 2012 at 2:37 pm
    Thanks Dan you rock!!
    But why do you say that should be 504 permutations (9*8*7) i don’t understand where comes the 9*8*7 ?
    And by the way where do i apply the code? To each layer or to a comp with all the layers inside?
    Thanks a lot for all the help!
  • Dan Ebberts
    November 13, 2012 at 4:31 pm
    The 9*8*7 comes from 9 choices for the first slot, which leaves 8 choices for the second slot, which leaves 7 choices for the third slot.
    You probably wouldn’t use that code unless you put together a script to build the comp for you.
    If you set up the comp by hand, with copies of all nine footage items in each of the three slots (assume slot 1 is layers 1-9, slot 2 is layers 10-18, and slot 3 is layers 19-27), you could use an opacity expression like this to calculate which layers should be visible, based on the current time:
    dur = 10;
    maxPerm = 9*8*7;
    curPerm = Math.floor(time/dur)%maxPerm;
    i = Math.floor(curPerm/56)+1;
    j = Math.floor(curPerm%56/7)+1;
    k = curPerm%7+1;
    if (j >= i) j++;
    if (k >= i) k++;
    if (k >= j) k++;
    if ((index == i) || (index == j+9) || (index == k+18)) 100 else 0
    This should give you a different permutation every 10 seconds.
    Dan
