Activity Forums Adobe After Effects Expressions Combination of keyframes and expressions
  • Combination of keyframes and expressions
    Posted by Emmanuel Gobert on February 19, 2008 at 6:26 pm
    hi everyone.
    I’d like to rotate several solids around Y axis.
    I want to do a serie of ratation, with a pause between each series. For this of course, I use keyframes.
    But eveytime the solids stop their rotation, I want them to have a sinusoidal decay around Y axis (like a vibration)… so then I need to use an expression, but only at specific keyframes…
    Is it possible, and how ?
    EDIT : here the result i want : https://fr.youtube.com/watch?v=nxmMfL9gcx8
    (i use only keyframes for this example)
    thanks in advance.
    Emmanuel Gobert replied 18 years, 6 months ago 2 Members · 3 Replies
  • Reynolds Strother
    February 19, 2008 at 10:20 pm
    I think this thread can help you out.
    https://aenhancers.com/viewtopic.php?p=1733#1733
    If you employee this method I think you’ll only need to apply the expression to one layer parented to a null creating the Y rotation. Then parent all your other layers to the layer with the expression, they should follow the vibration.
  • Emmanuel Gobert
    February 20, 2008 at 12:28 pm
    Thank you for answering, I will try this later
  • Emmanuel Gobert
    March 1, 2008 at 1:32 am
    Hi everyone,
    I’ve found this great expression which is solving my problem :
    n = 0;
    if (numKeys > 0){
    n = nearestKey(time).index;
    if (key(n).time > time){
    n–;
    if (n == 0){
    t = 0;
    }else{
    t = time – key(n).time;
    if (n > 0){
    v = velocityAtTime(key(n).time – thisComp.frameDuration/10);
    amp = 0.05;
    freq = 3.0;
    decay = 6;
    value + v*amp*Math.sin(freq*t*2*Math.PI)/Math.exp(decay*t);
    }else{
    value;
    I copy this in the rotation parameter, and on each keyframes that end a movement, it adds a little bounce effect.
    found on gray machine.
