Activity Forums Apple Final Cut Pro Legacy Comb-like artifact on moving objects in Final Cut Pro 4
  • Comb-like artifact on moving objects in Final Cut Pro 4
    Posted by Jon Davidson on December 19, 2005 at 5:12 am
    I’m getting an artifact problem on moving objects in FCP; the objects seem to have jagged edges when in motion, that resemble the teeth of a comb. I’ve heard of this “combing” artifact before. Can someone tell me what is causing it, and how I can eliminate it? Thanks for any input. (It also appears on projects that have been output to DVD and viewed on televison, so I know it’s not just a monitor problem).
    Jon
    Simon Webb replied 20 years, 9 months ago 2 Members · 1 Reply
  • Simon Webb
    December 19, 2005 at 7:47 am
    Jon,
    This sounds like an interlacing problem. You may want to try a de-interlacing plugin such as the one available from CGM (https://www.cgm-online.com/eiperle/cgm_e.html). Also, if you have After Effects, export the sequence as a QuickTime movie and de-interlace it from there.
