Activity › Forums › Adobe InDesign › columns problem
  • columns problem
    Posted by Ruby Gold on October 9, 2008 at 7:59 pm
    Hi there. I’m a newbie using CS3 and I have a text object with two columns. For reasons I can’t figure out (no matter how hard I try!), the top of the right hand column is slightly lower (almost one line length) than the left hand column. I’ve tried adjusting the frame, and the text wrap settings (two small pictures have text wrapped around them in the text object) checking line breaks in the text, etc, but nothing seems to fix it. The only thing that worked was going into the text frame options and setting the vertical alignment to “top.” Then the columns are even, but I can only set that if I select the ‘ignore text wrap’ box. But I need the text to wrap around the pictures. I’m so frustrated. Help with this greatly appreciated.
    Ruby Gold replied 17 years, 12 months ago 1 Member · 0 Replies
  • 0 Replies
