Activity Forums Apple Motion colours messed up, cannot reliably match colours
  • colours messed up, cannot reliably match colours
    Posted by Mark Palmos on July 2, 2010 at 10:00 am
    Hello all,
    I have a client who is particular about their brand colour. My video has to match the other blues on their site.
    Their brand colour is RGB 0, 175, 240 and it is WAAAAY off when I render it.
    The client rejected it. So I decided to match by eye/eyedropper.
    1/ get brand guidelines image from client
    2/ use eyedropper in Motion to match blue (looks identical)
    3/ render in Motion
    4/ colour of rendered MOV is visibly different and gets different readings using the eyedropper from the viewer in Motion, the client’s brand guidelines, so how on earth can I get this right, by trial and error?
    I have tried rendering with Gamma Auto and None, but it is still wrong. Help much appreciated!
    Tx
    Mark.
    Peter Heacock replied 13 years, 8 months ago 5 Members · 13 Replies
  • 13 Replies
  • Zak Peric
    July 2, 2010 at 11:18 am
  • Mark Palmos
    July 2, 2010 at 11:31 am
    Hi Zak,
    Nice tutorial, but it does not answer my question.
    I want a way to have a specific colour be identical after being input and output in Motion.
    My client’s blue colour is 0, 175, 240 which is easy to create in Motion, but when I render it out, the colour is COMPLETELY different from their brand colour. Motion renders the colour and changes it.
    Tx
    Mark
  • Zak Peric
    July 2, 2010 at 11:45 am
    Firs thing is, are you using hex values. Use the link from the tutorial I gave you to download the Hex for Apple Colour. Install it. Then use it to get the correct colours. My tutorial was actually explaining this in detail. Anyway, you also need to tell me what codec are you using to render your animation. If I am you, I wold use Animation codec. As this is a codec that is uncompressed, if you are using h264 (MP4), then what your client wants is not possible, as the degradation of colour will occur due to the codec limitatios of H264 codec.
    Also read this: https://en.wikipedia.org/wiki/H.264/MPEG-4_AVC
    I hope this helps.
    Let me know please..
  • Mark Palmos
    July 2, 2010 at 11:51 am
    Hello Zak
    Hex values are just convenient, not better or more accurate than entering RGB or CMYK values.
    I have entered the correct values. Exporting Prores 4444 or 422HQ or Apple Uncompressed all alter the colour upon export. If I bring the MOV back into the project it shows a different blue from what was originally there, so the problem is with Motion’s export.
    Mark.
  • Mark Spencer
    July 2, 2010 at 2:13 pm
    Here see if this is the problem:
    https://www.youtube.com/watch?v=dsiVZGNt-1U
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • Zak Peric
    July 2, 2010 at 5:03 pm
    Motion does have tenancies to get the colours wrong. As per Mark Spencer turorial. Hex values are very accurate and it is something you should use all the time in my opinion.
    Can you please try to export again, this time use Animation codec not Apple Pro Res 444.
    There is a difference in codecses, As far as I know 4444 is compressed while Animation codec is not.
    If this does not work then copy all of your layers and paste them in a new Motion Document, save it, then re-render the animation.
    You can also try as a last resort to delete Motion preferences, then render agin.
    Let me know how you get on.
  • Mark Palmos
    July 3, 2010 at 8:21 am
    Hi Zak, thank again for the response mate,
    On friday I had to match it by eye, using the same rgb values was way off (not even close!) I then rendered an uncompressed apple version and am now holding thumbs the client will approve.
    I hope the motion team at apple know about this, it really isnt good enough to be used in a professional environment. It is embarrassing when they give me exact rgb values, and I give it back to them looking a different colour.
    WRT the hex values, AFAIK, every rgb value has a hex value. the client supplied exact rgb values, so I would have to go with what they gave me, unfortunately Motion had a very different idea of what that blue colour should look like.
    thanks again,
    Mark.
  • Mark Palmos
    July 3, 2010 at 8:25 am
    Hi Mark, thanks for that, interesting, but not what I was experiencing.
    The colours were a lot less similar to the ones in your example, which may have been accentuated by the bug you show here. Also the colour matching by picker is very flawed in my experience, because the picker in Motion will show different rgb values for the same colour, depending on which monitor I use the picker on!!! So it seems to pick a colour depending on what it looks like ON THE MONITOR rather than it’s real “computer value”.
    Catch you later,
    Mark
  • Mikey Bouchereau
    July 5, 2010 at 3:55 pm
    If animation export is still doing a color shift, try using no compression at all. The Animation Codec is near lossless (and for most cases people will say its lossless, including myself) but like one of college professors used to say the only true lossless compression is to choose None as your codec, this will not introduce anything add a color shift.
    Also I ran into a Color shift from AE and Motion when I had a AJA card installed by removing their uncompressed codec from my QuickTime folder it fixed the issue.
    Mikey B!
    Follow Me On Twitter!
    Check Out My Sky Replace Tutorial
  • Peter Heacock
    January 17, 2013 at 3:27 pm
    Mark,
    I’m having a related issue. Where do I find the color values in Motion 5? I can’t right click below the view bank of controls. I’m trying to match the values of my blacks between layers.
    Cheers!
