Activity Forums Adobe After Effects Colour Question – White.
  • Colour Question – White.
    Posted by Mr_steven on August 20, 2006 at 11:29 pm
    I’ve just filmed my first music video and the singer is dressed in a white suit, and was shot against a bluescreen. I need to replicate him (which I can do), but I need to change the colour of his suit without affecting the flesh tones in his face. Is this possible to do this in AE ? Without masking the figure, and if so how ?
    Thanks.
    Steven.
    Mr_steven replied 20 years ago 2 Members · 2 Replies
  • Filip Vandueren
    August 21, 2006 at 12:09 am
    precompose your keyed figure.
    If you look at your blue channel this has probably the highest contrast of suit vs. skintones.
    You should try to get a luma key out of that to put the fleshtones on a new ( duplicated) layer.
    then just tint, colorama, multiply, colour correct, or by whatever means you want to colourize your white to your new suit-colours.
    Good luck ! Can’t garantuee you’ll get perfect results though…
    You could also try to auto generate some masks by using autotrace based on a threshold of the blue channel. (see Aharon’s video podcast tutorial on supertight garbage mattes)
  • Mr_steven
    August 21, 2006 at 3:55 am
    Thanks for that, it seems to be working ok.
