Activity › Forums › Apple Final Cut Pro › Colour matching with 2 views
  • Colour matching with 2 views
    Posted by Kris Forge on February 22, 2013 at 1:02 pm
    Is there a way to view 2 clips at once for colour matching. I know this happens when you do the auto colour match but I want to work manually as colour match is working poorly in this instance.
    I guess it would lookvkinda like the old viewer and canvas in previous fcp. Thanks
    Kris Forge replied 13 years, 7 months ago 3 Members · 4 Replies
  • David Eaks
    February 22, 2013 at 2:29 pm
    Just a tip for color matching.
    Say you have two angles of the same subject, a CU and a wide. The subject is on stage with a colorful background, CU shot is primarily skin tone and colorful background, while the wide shot has a lot of black in the frame surrounding the stage. These won’t color match well because of all the black. If you temporarily scale the wide shot way up so it is at least similar in overall composition to the close-up, it will match much better. Then reset the scale back to normal. You might be pleasantly surprised by how well (and fast) it can actually work.
    For manual color matching have you used the Event Viewer? Select Window> Show Event Viewer. It should be just what you’re asking for.
  • Kris Forge
    February 22, 2013 at 3:39 pm
    Thanks for the tip David, sounds like a great idea. I’ll be sure to try that out on a future project. In this project the clips are already very similar, 2 angles of an interview. I’ll try it anyway.
    The event viewer is not really what I’m after as I want to see a clip in the timeline that I have already corrected. Then be able to compare that to another clip later in the timeline that I want to visually match.
    Thanks for your help.
  • T. Payton
    February 22, 2013 at 4:23 pm
    This is what I do:
    1- Create a new event and call it “Color Grades” for example.
    2 -Show the Event Viewer (Control-Command-3)
    3 – Make a compound clip of the already corrected clip in the timeline, store in the new event. (Option-G)
    4 – With the now compound clip still selected show the frame in the event viewer with Shift-F.
    5 – Back in the timeline, restore the original reference clip with Break Apart Items (Command-Shift-G)
    6 – Move your playhead to the clip you want to color correct by option clicking and it will load it the now timeline viewer and you can color correct.
    This sounds like a long process but it is actually very fast. For larger projects I find that creating that additional event is very helpful. I store not only my color grades, but also references I like from other movies, stills, etc. I tend to make only a few master grades to match to, rather than matching to every previous shot.
    I also like to open up scopes to match both the event and the standard viewer.
    T. Payton
    OneCreative, Albuquerque
  • Kris Forge
    February 22, 2013 at 4:50 pm
    Thanks for that detailed work around. Sounds like a good solution to my problem. I new to this so I appreciate the help. It surprises me though that something so basic is not achievable as standard in fcp.
    Thanks all.
