Activity Forums Adobe Premiere Pro Colour grading / S-log footage – Workflow
  • Colour grading / S-log footage – Workflow
    Posted by Joao Pereira on August 15, 2017 at 10:50 am
    Hi everyone,
    I receive a lot of rushes shot in s-log2 and s-log3. I’m very far from an expert in colour, etc, but sometimes the client requires a short turnaround and I’ve been using Lumetri in Premiere most of the times. However, I’m still searching for a more fluid and quick workflow which can deliver good results. Most of the footage is shot for web content and I’m only looking for standard natural looking colours.
    I have tried downloading different LUT’s to grade the footage as rec709 and have a good reference or a starting point but none of them seem to do it properly. The results are always very off after applying the LUT. . I’m probably doing something wrong and would like to know your input.
    What’s your workflow to grade Slog footage with Lumetri?
    Cheers,
    Neil Kendall replied 8 years, 5 months ago 4 Members · 5 Replies
  • Chris Wright
    August 15, 2017 at 11:29 am
    you could make a lut in lumetri, export it as 1_yourfile and it will pop up at the top dropdown menu.
    or you could try my free effect preset which works as 32bpc( 0 precision loss) effect which simply normalizes what you recorded.
    free slog 3 to rec709 effects preset for premiere.
    create a vibrant film look from slog3 footage without speedgrade or any luts!
    a tweakable effects preset that can be modified to work for slog2 or any other flat look in only a few seconds.
    how does it work? it uses fast color corrector as a pre-contraster limiter for brightness/contrast filter.
    Simply edit fast color corrector input white black and output white black. drag effect onto footage or adjustment layer.
    https://f1.creativecow.net/file.php?id=9975&folder=slog-3-to-rec709-effects-preset-for-premiere
    -the fastest turnaround would be to make each clip look the same first, then apply one adjustment layer to all clips for color.
    https://forums.adobe.com/thread/2117929
    -make your own lumetri lut
    https://forums.adobe.com/thread/2211190
  • Greg Janza
    August 15, 2017 at 4:24 pm
    I work with slog3 footage regularly and my normal workflow is to add a kodak lut (5203 NEG) to all of the footage. I’ve also used filmconvert in the past and that works well too.
    the key to adding these LUTS to a timeline is being able to make use of the Mercury Playback engine (CUDA). this allows for easy playback and faster rendering.
    I Hate Television. I Hate It As Much As Peanuts. But I Can’t Stop Eating Peanuts.
    – Orson Welles
  • Joao Pereira
    August 16, 2017 at 8:54 am
    Thank you very much Greg.
    I’ll give it a try.
    Cheers,
  • Joao Pereira
    August 16, 2017 at 9:22 am
    And thank you Chris. I’m giving it a try to your preset now.
    Cheers,
    Cheers,
    João Pereira
  • Neil Kendall
    March 14, 2018 at 1:32 pm
    Hi Chris,
    Thanks a lot for sharing your slog 3 to rec709 effects preset for Premiere. I’m trying to use it on a Mac, but to no avail. Do you have any tips for importing in to Prem?
    Many thanks,
    Neil.
