Activity Forums Apple Final Cut Pro Colour flickering when adding any titles / generators / images over timeline
  • Colour flickering when adding any titles / generators / images over timeline
    Posted by Phil Davies on January 20, 2018 at 4:58 pm
    A couple of weeks ago I noticed an intermittent colour and lighting flicker in my projects. Footage is always from the same cameras with the same settings.
    This isn’t a persistent flicker – it’s almost as though the white balance or exposure is changing every few seconds on the cameras. I don’t think it’s a camera issue because it’s occurring on multiple different camera angles in the same project.
    I’ve tried deleting and reinstalling FCPX but this has had no effect
    I’ve opened the projects on different Macs and get the same issue.
    Here’s some test footage. Look at the green paper on the easel to the left, or the lime on the shelf in the lower right, as that’s where it’s most noticeable:
    https://art-tutor.wistia.com/medias/qgcstnib9n
    Any help would be very much appreciated.
    Phil.
    Katy Barclay replied 8 years ago 7 Members · 31 Replies
  • 31 Replies
  • Jeremy Garchow
    January 21, 2018 at 4:50 am
    Does this happen if you playback the footage in Quicktime?
    What happens if you playback the footage without the titles?
  • Phil Davies
    January 21, 2018 at 11:09 pm
    Ok so the clips play fine in QuickTime.
    If I remove the titles it does improve the flickering in that area but there is still flickering elsewhere on the timeline where there are no titles. The tiles are FCPX presets and not a third party plugin.
    I need to do more tests but it seems like creating a new project and adding in the footage without any titles or other overlays works ok. As soon as I add anything above the primary timeline it triggers the issue, which remains in places even if I then remove all those overlays.
  • Jeremy Garchow
    January 22, 2018 at 3:02 am
    [Phil Davies]
    If I remove the titles it does improve the flickering in that area but there is still flickering elsewhere on the timeline where there are no titles. The tiles are FCPX presets and not a third party plugin. “
    First think I would do is trash your cache files.
    If that doesn’t work, I’d trash your preferences.
  • Jagster Rana
    May 17, 2018 at 4:00 pm
    Hi Phil
    did you ever get a solution to this…. ?! im having the exact same problem ( i dunno if its isolated to canon c100 cameras )
    but the same damn colour from light shade to dark shade. Ive done the following to try to fix all without joy :
    deleted render files at library level, at event level at project level
    deleted prefs
    created a new library on a different drive
    i cant send out this work as the editing and camera works is all fine but this ” colour flicker ” makes me look unprofessional :((
    any help / any one PLS ?
    thanks
    JR
    JR
  • Jeremy Garchow
    May 17, 2018 at 4:55 pm
    [Jagster rana] ” cant send out this work as the editing and camera works is all fine but this ” colour flicker ” makes me look unprofessional :(( “
    Does the flicker happen when titles are up?
    Can you post an example?
  • Jagster Rana
    May 17, 2018 at 6:35 pm
    HI Jeremy
    thanks for yr reply
    according to my research its a known problem but apple are not acknowledging it ? this has also been posted on the apple forums … v long thread
    doubt titles are connected to this issue heres why…
    the media is fine on the camera
    fine when playing on QT
    ONLY when its playing within fcpx ( using 10.4) do you see the “colour bug ” even before importing it onto a timeline i can see it on the import window when transcoding.
    have also deleted render files at library level, at event level at project level
    deleted prefs
    created a new library on a different drive and still issue persists !!
    look at this clip ( not mine) but someone with same issue
    if you look at the plate with the lemons and limes you see the colour go from light to dark
    ive also read the issue affects reds the mosts and this is true for me…
    so let me know if you have any ideas pls
    thanks
    JR
  • Jeremy Garchow
    May 17, 2018 at 7:27 pm
    In that video, it looks like text overlays are effecting it, so it’s hard to tell.
    What happens if you optimize a clip. Does it still show the symptoms?
  • Jagster Rana
    May 17, 2018 at 8:16 pm
    in a nutshell … yes
    the issue is happening ONLY when you transcode with fcpx… the clock is ticking for me so im thinking if i transcode with fcp 7 ( lucky i still have on another machine ) then import back in fcpx shld be ok.. of course im assuming it will not want to transcode the transcoded footage !!!!!
    JR
  • Jeremy Garchow
    May 17, 2018 at 8:40 pm
    This is footage that you imported in to FCPX, and it transcodes it?
    What if you just import the original footage without a transcode?
  • Jagster Rana
    May 18, 2018 at 1:44 pm
    the files in question are AVCHD.. ( mts files from canon c100)
    so if u import it will transcode automatically.. correct me if im wrong ? besides it will struggle to play files if not transcoded ..no ?
    JR
Page 1 of 4
