Activity Forums Adobe After Effects Colour Fading – PNG sequence (flash) to After Effects
  • Colour Fading – PNG sequence (flash) to After Effects
    Posted by Sophie Watson on May 29, 2008 at 6:11 pm
    Hello!
    I wonder if anyone could shed on what happened in my last animation project.
    I selected beautiful colours in flash and in my AE project they were desaturated.
    By the time they appeared on the TV screen, it also was very “flashy” – it’s hard to explain – the colours were pale but it seemed as though they were far too bright.
    Currently working on a new project with Flash 8 and After Effects CS3 and want to avoid the same problem or at least investigate it.
    Process in last project:
    Created animation in flash 8 on a PC (windows xp service pack 2)
    Exported as png sequence
    Imported PNG sequence to After effects (5 or 7 – i can’t remember which version it was at the time)
    Shocked by very dull appearance of PNGs in After effects
    Experimentally adjusted luminance level/broadcast something or other to try and make it more saturated.
    Exported as quicktime
    Authored DVD in DVD studio pro
    I suspect the following – but would be grateful for your opinion.
    Settings in flash for exporting PNGs – e.g.
    24 bit with alpha
    filter: none
    smooth
    Do i need to temporarily change my screen settings when editing my project and is this advisable?
    e.g. would i risk mess up the appearance of a large body of existing design work?
    Is this a known issue when importing pngs to After effects?
    Is this a graphics card issue?
    Would upgrading to Flash CS3 help at all?
    Many thanks..
    Sophie Watson replied 18 years, 3 months ago 2 Members · 2 Replies
  • Joey Foreman
    May 29, 2008 at 8:34 pm
    Have you tried exporting as a .psd or .tif sequence? I don’t use .png very often so I’m not sure what sort of color profile issues it might have.
    Joey Foreman
    Editor/Animator
    Nowhere Productions, Athens, GA
  • Sophie Watson
    May 30, 2008 at 5:54 pm
    thanks for this suggestion.
    i think it happened when i exported it as a quicktime movie.
    at the moment i’m trying to focus on production but will try a test export as a tiff and see what happens.
    have you ever experienced a thing where you pull in a movie/sequence to AE and find it is way too bright/desaturated?
