Activity Forums Apple Final Cut Pro ‘Colour’ doesn’t ‘stick’?
  • ‘Colour’ doesn’t ‘stick’?
    Posted by Brian Thomas on January 6, 2025 at 11:39 am
    For many years, when clicking on the colour triangle, the “Color Board” would come up for me (it’s the one I’m used to). Recently I’ve been getting an intermediate screen entitled “Enhance Light and Color” from which I then have to choose the board, wheel or curve I feel appropriate. Is there any way of going straight to my prefered tool? This intermediate screen is very tiresome. Thanks for any help here.
    Brian Thomas replied 1 year, 7 months ago 4 Members · 7 Replies
  • 7 Replies
  • Brian Thomas
    January 6, 2025 at 12:39 pm
    FCP Version 11, MacBook Pro 16″, Apple M1 Max, Sequoia 15.1.1
  • Eric Santiago
    January 6, 2025 at 2:40 pm
    Well that sounds annoying.
    Not using 11 yet so I cant seem to figure out your issue.
    I did do a Google and are you sure you didn’t select it at import?
    Its the enhanced button and sorry if I’m wrong.
    Need to upgrade sometime in the near future.
  • Doug Metz
    January 6, 2025 at 4:28 pm
    Hey Brian,
    That’s the new default panel in 11, but you can set it to whichever one you prefer:
    Settings -> General -> Color Correction
  • Brian Thomas
    January 6, 2025 at 4:31 pm
    Thanks for that Eric. Actually, it’s turning out to be pretty impressive. I was videoing a local amateur production with a variety of different (but almost similar) camcorders all over the hall and quite a lot of the time it’s giving good results! Amazing!
  • Brian Thomas
    January 6, 2025 at 4:32 pm
    I hoped there would be a way – many thanks Doug!
  • Devrim Akteke
    January 6, 2025 at 6:40 pm
    That’s not normal behavior. That option only appears if you applied Color Enhance to a clip or Color Balance is checked in your import settings.
  • Brian Thomas
    January 7, 2025 at 8:21 am
    Hello Devrim – thanks for your concerns but having had this explained, swapped between the options and generally messed around I’m pretty happy with the behaviour.
    I’m not happy with the inconsistencies in FCP behaviour surrounding the use of the Ken Burns effect on video clips but that is for another thread on another day 😉 One day I’ll take the time to write it up.
