Activity Forums Adobe After Effects Colour correction: removing yellow light
  • Colour correction: removing yellow light
    Posted by Ian Collister on April 13, 2009 at 10:12 am
    Hi all
    Have recently shot some footage that has a lot of yellow light in it. Which of the colour correction tools is best for removing the yellow? I dont want to strip out all the yellow, i just want to reduce it, leaving me with a more balanced piece of footage.
    Cheers
    I.
    Ian Collister replied 17 years, 4 months ago 3 Members · 3 Replies
  • Curious Turtle
    April 13, 2009 at 2:07 pm
    Without seeing a screenshot, I would recommend either:
    i) Curves – Add blue mids, remove red mids to cool the shot down.
    ii) Hue/Saturation – Just select the yellows, and tweak the saturation and possibly the hue a touch.
    If you want even more control on it, use Color Finesse and tweak your yellows in the secondary tab. Select your range, then push the hue offset towards the blue to neutralise your yellow.
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
    Just out: Rock Steady : Successful Motion Tracking in Mocha & After Effects
  • Brendan Coots
    April 14, 2009 at 3:26 am
    As ben mentioned, yellow is directly related to blue, so if you want to remove yellow you must increase the blue component. You can do this quite easily with the “Color Correction>Levels” tool. Apply it to the footage, and use the dropdown to select the blues.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
  • Ian Collister
    April 14, 2009 at 11:58 am
    Thanks guys.
