Activity Forums Adobe Premiere Pro Colour Correction not exporting on clip, Premiere Pro CC
  • Colour Correction not exporting on clip, Premiere Pro CC
    Posted by Mark Coory on March 24, 2014 at 1:16 am
    Hello
    I am trying to broadcast safe a project I am working on and have come pretty close to colour safe levels. However I seem to be a little over white exceptance. So I’ve added a levels effect to pull down the bright areas, then I re-export the clip complete with changes, bring it back into PP and the effect hasn’t shown up in the export. I have applied the clip both to an adjustment layer and the clip itself.
    See image
    The image on the left is slightly over 1volt colour safe. Then I add the levels effect (on the right) which corrects it, then export. Once I bring it back in the levels are still as they are on the left.
    I’m exporting to Prores 422, MPEG2 and also exporting using sequence settings. No joy.
    Any ideas?
    Mark Coory replied 12 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
