Activity › Forums › Apple Final Cut Pro Legacy › Colour correcting in FCP – before or after Magic Bullet?
  • Colour correcting in FCP – before or after Magic Bullet?
    Posted by Andrew David on May 13, 2010 at 1:41 pm
    I’m going to apply some magic bullet looks (grading) in FCP 6. Should I do this before or after I colour correct my footage (also in FCP)? By colour correct I mean getting my blacks and whites to broadcast standard.
    If I do the blacks and whites first, will the looks I apply in MBullet mean I will have to go back and redo them again to broadcast spec?
    Cheers,
    Andrew
    Andrew David replied 16 years, 4 months ago 2 Members · 2 Replies
  • Shane Ross
    May 13, 2010 at 4:06 pm
    [Andrew David Clark] “By colour correct I mean getting my blacks and whites to broadcast standard. “
    That isn’t what color correct means, but…OK. No, that is the overall correcting of the image. GRADING is the term used when you just adjust the look.
    You kind of do it at the same time. How can you adjust the black and white points without color correcting at the same time? It all should be done at once. That is part of achieving the look.
    [Andrew David Clark] “If I do the blacks and whites first, will the looks I apply in MBullet mean I will have to go back and redo them again to broadcast spec? “
    Why can’t you do it at the same time? OH, because looks doesn’t allow for external monitoring, so you can’t REALLY tell? That’s a problem. But yeah, I’d do it AFTER. Actually, I’d choose someting that allows me to do both at once, and see what I am doing.
    Shane
  • Andrew David
    May 13, 2010 at 4:26 pm
    Thanks, Shane. I guess then I shall be flipping back and forth betwixt the three way colour corrector and Magic Bullet. Oh boy, I’m in for a zillion hours of work, lol!
    Cheers mate
