Activity › Forums › Apple Final Cut Pro Legacy › colour codec?
  • Posted by Isabel Castro on August 24, 2007 at 8:14 pm
    Hello,
    when I use anything coloured in my sequence (texts or something graphic imported)it flicks a lot. Especially colours like red.
    Is there anithing I can do? May be somekind of codec that might solve this problem?
    Thank you,
    Isabel
    ps.: I’m not american, but I hope I made myself inderstandable.
    Rafael Amador replied 19 years, 1 month ago 3 Members · 2 Replies
  • David Roth weiss
    August 24, 2007 at 9:21 pm
    Isabel,
    If you’re using DV then red will definitely give you fits much of the time. Moving to an 8-bit or 10-bit uncompressed timeline can help. Give it a try. Of course uncompressed requires more hard drive throughput than DV, so you must a have raid array to use them.
    David
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    POST-PRODUCTION WITHOUT THE USUAL INSANITY
  • Rafael Amador
    August 25, 2007 at 4:41 am
    Hi Isabel,
    Do what David says. Set your sequence in 8/10b and drop the Nattress “Chroma Sharpening” filter. The red will be back to the object instead of spreading all around.
    Cheers,
    Rafael
