Activity Forums Apple Final Cut Pro Legacy Colour changes when exporting
  • Colour changes when exporting
    Posted by Tom Bailey on May 27, 2012 at 10:08 pm
    I’m having trouble with colours being altered when I export a project.
    I needed to re-do some work on the sound for a film, but I no longer have the video media for my final sequence, which was finished in After Effects (which I don’t have).
    So instead I was working off the final quicktime, exported using Apple ProRes 422 HQ codec. When I tried re-export it now the colours and brightness/contrast change quite significantly. I have tried making adjustments and exporting a few frames but besides being a laborious process, it also doesn’t seem to be bringing in the results I need.
    Any recommendations on how to stop the colours from altering?
    Or a way/ program (preferably free or cheap!) that I can jam the previous video export and the new sound together in, without re-exporting?
    Thanks for all your help,
    Bailey.
    Tom Bailey replied 14 years, 3 months ago 2 Members · 2 Replies
  • Michael Gissing
    May 28, 2012 at 4:16 am
    Well you can add your mix files to the original quicktime using Quicktime Pro. That doesn’t solve the issue of why there would be a shift.
    If you import the QT into FCP and drag into a timeline you should get a prompt to adjust the sequence settings to match the file. Say yes and then you should be able to export a quicktime movie using current settings without any shift in color or contrast.
  • Tom Bailey
    May 28, 2012 at 8:57 pm
    Thanks Michael I’ll try both of those!
