Activity Forums DaVinci Resolve ColorTrace can’t see same project?
  • ColorTrace can’t see same project?
    Posted by Brandon Kraemer on May 30, 2013 at 9:10 pm
    Had the perfect situation to attempt ColorTrace today, except I couldn’t get ColorTrace to see the project I was working from where the other sequence already existed.
    Is it not possible to ColorTrace from one sequence to another with in the same project?
    Does it matter if “Copy Remote Grades to Local” was used with in the project perhaps?
    Resolve v.9.1.3.019
    OS X 10.8.2
    Brandon Kraemer replied 13 years ago 3 Members · 3 Replies
  • Toby Tomkins
    May 30, 2013 at 9:31 pm
    This is indeed the case. Duplicate the project using ‘save as’ in the project area.
  • Simon Tingell
    September 5, 2013 at 11:34 am
    Hey!
    [Brandon Kraemer] “Does it matter if “Copy Remote Grades to Local” was used with in the project perhaps?”
    Did you get a solution for this? I did the same thing I copied the grade to local and now I need it back in remote so that I can see the grade in the master timeline. Need to extend the tracks for handles.
    Simon
  • Brandon Kraemer
    September 6, 2013 at 8:43 pm
    I believe Toby answered this question, you can’t color trace one sequence to another within the same project… you have to save as first and then color trace from the pervious version into the new. Honestly I haven’t found an instance when ColorTrace worked. However if I have grades already in the project before I copied remote to local (which I almost always have to do) the mater sequence grades auto populate onto the new sequence I’ve added… with mixed results.
