colorspace and pulsing in renders
Hi, I am working in FCP with uncompressed 8 bit footage captured on a Kona 3 from HDCAM. The footage plays fine in FCP. I take the footage in AE (CS3) and do the FX needed and render the footage to uncompressed 8 bit again. When I bring the clips back into FCP I am getting a pulsing effect on the video. The Mac also has a Kona 3 in it. In one shot, with a lot of green grass, the green channel was pulsing. I looked at it on a scope and the green channel was bouncing up and down. I composited another clip and the same help true for the red channel. It seems every render from AE has this pulsing artifact in it. I have tried several things to remedy the problem but nothing seems to work.
I also noticed that the color of the clips is different than the original footage. I have tried many different project colorspace settings like “HDTV (Rec. 709) 16-235” or “HDTV (Rec. 709)” and also “none.” Each of these will alter the color of the video but nothing I select renders the footage with the EXACT color of the original clip. And on top of that there is this strange pulsing.
One thing I did notice is that if I reduce the saturation of the clip a bit in FCP (3 way CC) the pulsing stops.
HAs anyone had similar issues or know what is going on here?
Thanks…
