Activity › Forums › Apple Motion › Colors window not responding
Posted by Reneon on September 12, 2005 at 5:57 pmHi
The Colors window response is erratic, often it doesn’t update the colour.
Anyone else with this problem/bug?
Rene
Greg Niles replied 21 years ago 4 Members · 4 Replies -
Kasey Capone
September 12, 2005 at 8:10 pmI’ve noticed that a single click works to select colors.
Double clicking on the original color in order to select a new color tends to
get me nowhere. -
Reneon
September 12, 2005 at 10:35 pmKasey
Maybe that’s it, I’ll try tomorrow.
Why would the window open up on a dbl click but not function? that’s not right..
Rene
Jim Kanter
September 16, 2005 at 5:47 pmWhat happens when you control/right-click on a color well? Do you get the Motion color picker?
Jim Kanter,
Digital Film Institute
http://www.dfilminst.com -
Greg Niles
September 16, 2005 at 7:55 pmIn Motion the Colors window it works exactly like the system color picker. Single click opens the palette and also selects the color well for editing. If you want to pick a different color well while the Colors palette is still open, just click on it (it should highlight darker). Clicking on a color well “de-selects” it so it no longer responds to the Colors palette.
The reason why the double-click isn’t working is because when you double-click, you’re basically clicking once to get Colors window, then clicking again immediately after to de-select the color well, which breaks the link between the window and the color well that needs to accept the changes.
— Greg
