Activity Forums Adobe Premiere Pro Colors loss on YouTube (shift washed)
  • Shane Ross
    August 16, 2017 at 9:54 pm
    There is nothing you can do. YouTube recompresses the footage when you upload, to the varying formats to play back depending on the internet speed of the user. That recompression causes this…and you cannot control what they do. You can only provide them the best quality file to work from…beyond that, it’s out of your hands.
    Also know that various players also play back differing quality….VLC and QT and other players won’t have the same look. Similarly, Firefox, Chrome, Safari, Explorer…even if watching the same video on YouTube, the colors will look different. Why? Who knows…that’s the code of the apps.
    Shane
    Little Frog Post
  • Alex Ivamov
    August 21, 2017 at 6:29 pm
    I found the answer. The problem in the rating of the channel!
    Here you can see the video. There are English subtitles.
  • Alex Ivamov
    August 21, 2017 at 6:31 pm
    https://www.youtube.com/watch?v=Vjmdcs1pWNA
  • Chris Wright
    August 22, 2017 at 7:15 am
    If you’re still having problems with youtube, it could be youtube changing the gamma/pixel values, in which case
    you can try manually baking in a new look similar to avc1 vs vp9.
    many people have had luck using this LUT I made for youtube/vimeo.
    64 cube iridas lut for burning in darker 16-235 from 0-255 for youtube upload. it darkens image, then youtube/vimeo re-lightens again.
    https://f1.creativecow.net/10598/fixmyyoutube
    note:
    it doesn’t work with adjustment layers directly
    you have to use it in the dropdown for the export in adobe media encoder. or you can NEST it first.
    its a premiere bug. also it needs to be copied in both premiere-lumetri-technical and adobe media encoder-lumetri-technical
  • Yair Bartal
    August 22, 2017 at 1:28 pm
    Chris, is Adobe aware of this bug?
  • Chris Wright
    August 22, 2017 at 11:40 pm
    i sent in a bug report. I seem to be the only one to find bizarre nesting bugs like this. then again, I use a pixel level system color picker to nitpick a lot of things.
