Activity Forums Adobe After Effects Colorista II, Primary HSL wheel causing color break up/blockiness
  • Colorista II, Primary HSL wheel causing color break up/blockiness
    Posted by James Cookson on October 26, 2011 at 3:15 pm
    Hi, I’ve been using colorista II to color correct some canon DSLR footage in After Effects CS5.5. Everything works great until i use the Primary HSL wheel, even with the smallest alteration I get a suitable break up/ blockiness appearing randomly in the footage. I’ve tried it on different footage formats and with different color bit depths in the project, and I still get this issues. I’ve attached a shot below. Any help would be greatly appreciated
    Cheers
    Brian Carter replied 12 years, 3 months ago 4 Members · 4 Replies
  • Walter Soyka
    October 26, 2011 at 4:26 pm
    Does the blockiness go away if you change Colorista II > Options > Render using to CPU?
    Walter Soyka
  • Deleted User
    October 26, 2011 at 8:08 pm
    If you are trying to color correct a highly compressed codec like H.264 which originated in 4:2:0 color space, you might run into issues like that if you are really pushing the limits.
    Lee
    SAMDOG Digital Post
    Calgary, Alberta
    Mac Pro 2.66 12-core 16gb ram • FSI LM1760W Monitor • Matrox MX02 • Caldigit HD One 8tb Raid • Avid Artist Transport • Media Composer 5.5 • Final Cut Studio 3 • Premiere Pro CS5
    • Living my life one frame at a time •
  • James Cookson
    October 26, 2011 at 8:38 pm
    Thank you so much this seems to have done the trick, hadn’t even noticed that option!
    Cheers
  • Brian Carter
    May 28, 2014 at 6:20 pm
    This is an old post but just wanted to mention that the above fix also fixes a perpetual rendering problem in Premiere CC, where a clip never finishes rendering.
