Activity Forums Apple Final Cut Pro Legacy Colorista – Hardware cannot render at the requested size and depth
  • Colorista – Hardware cannot render at the requested size and depth
    Posted by Max Frank on January 17, 2010 at 11:23 am
    I’ve done a search but am not clear how to proceed.
    I’ve got a 1920×1080 ProRes timeline and on clips with Colorista
    applied I get a warning that says, “Hardware cannot render at the requested size and depth”.
    Below are my machine specs – I just want to know if there’s a work-around for what I’ve currently got, or if my system isn’t beefy enough to handle the task.
    [Note, I don’t have a IO box like Matrox or Kona, etc.]
    Thanks in advance,
    Wayne
    GeForce 8600M GT:
    Chipset Model: GeForce 8600M GT
    Type: Display
    Bus: PCIe
    PCIe Lane Width: x16
    VRAM (Total): 256 MB
    Vendor: NVIDIA (0x10de)
    Device ID: 0x0407
    Revision ID: 0x00a1
    ROM Revision: 3175
    Displays:
    Color LCD:
    Resolution: 1680 x 1050
    Depth: 32-bit Color
    Core Image: Hardware Accelerated
    Mirror: Off
    Online: Yes
    Quartz Extreme: Supported
    Built-In: Yes
    DELL2407WFPHC:
    Resolution: 1920 x 1200 @ 60 Hz
    Depth: 32-bit Color
    Main Display: Yes
    Mirror: Off
    Online: Yes
    Rotation: Supported
    Rafael Amador replied 16 years, 7 months ago 3 Members · 4 Replies
  • Rafael Amador
    January 17, 2010 at 12:06 pm
    Hi Wayne,
    Your GPU is not enough.
    Try unplugging your second display when rendering, this should free some resources for FC to work.
    If doesn’t works like that you will need to work in 720 or with an 8b codec.
    rafael
    http://www.nagavideo.com
  • Shane Ross
    January 17, 2010 at 5:34 pm
    I concur. That issue typically means the graphics card isn’t powerful enough. And FCP tends to rely more on the graphics card for some plugins…Colorista is one of them.
    Replace it with an ATI 4870 or 3870.
    Shane
  • Max Frank
    January 18, 2010 at 9:46 am
    Gents,
    Thanks for taking the time.
    You were both quite right about the problem – and Rafael, your work-around suggestion worked brilliantly – thanks.
    I just unplugged my 2nd monitor at the render stage and all was hunky-dory.
    I’ll need to get a beefier GPU and/or Mac – no doubt.
    Thanks again,
    Wayne
  • Rafael Amador
    January 18, 2010 at 10:12 am
    I’m waiting for the next Mac Pro update to get one.
    The story of the GPU is very limiting.
    Things some time works, some times no.
    Many times you do not get the warning and after rendering you fin something very ugly.
    Everything that is processed in the GPU could be processed in the CPU, but is up to the developers to add the option.
    rafael
