Activity Forums Adobe Photoshop coloring inner shadows
  • coloring inner shadows
    Posted by Amanda Smith on April 25, 2009 at 10:17 pm
    I am working on this tutorial
    https://www.lunacore.com/photoshop/tutorials/tut009.htm
    and it is telling me to make a white inner shadow for an effect. The problem i’m running into is that whenever i tell the layer style that i want to make the shadow a lighter color than the fill color of the circle i don’t see any shadow at all. I tried filling the circle with black to see if it would show up then but it still doesn’t. i can see black and darker colored shadows fine but not the white. am i missing something?
    ~ava
    Steven Hart replied 17 years, 4 months ago 2 Members · 1 Reply
  • Steven Hart
    April 27, 2009 at 8:51 pm
    Yes, you need to make sure the blend mode is set to Normal. By default the Shadow style’s blend mode is Multiply, or something of the sort. Change it normal and colors will behave as you expect.
    On this note, if you master blending modes, you will master Photoshop.
