Activity Forums Blackmagic Design Color/Gamma issue
  • Color/Gamma issue
    Posted by Steve Kellener on March 24, 2006 at 11:19 pm
    I rendered out a scene from After Effects 6.5 on a Mac G5 and a Windows PC both using the Blackmagic 8 bit setting. The two quicktime files appear different. The PC version is much darker (different gamma?) I tried the render using Animation compression and both files look identical.
    Is there a setting somewhere for the Blackmagic codec I need to set on both machines to get them to render the same way?
    Thanks in advance for your help.
    Steve Kellener
    Digital Compositor
    Titmouse, Inc.
    Artefact replied 20 years, 5 months ago 2 Members · 1 Reply
  • Artefact
    March 25, 2006 at 11:06 am
    we do have the same problem. clips were captured an rendert out to blackmagic 10bit uncomp in fcp on a mac. we imported this files and tried to ad a dissolve in premiere pro2 on a pc and the rendert dissolve is different. the clip plays perfekt without rendering, but when we try to aply effects that need rendering there is a huge different between the original and the rendert clip.
    any suggestions?
