Activity Forums Apple Final Cut Pro Legacy Colored .PNG graphic/text files become jagged in FCP after import to timeline.
  • Colored .PNG graphic/text files become jagged in FCP after import to timeline.
    Posted by Matthew Taylor on September 13, 2012 at 10:37 am
    Hello All
    Afraid I couldn’t find any answers to this anywhere else. It seems like a very specific problem. I am currently working on a trailer for a client that has text elements. I am working in PRO RES 422, 1920 x 1080, Square pixels. I have been making white text graphics with the same properties in .PNG format in Photoshop and importing in and all is fine.
    I then wanted to add some color to text later on in the trailer. I have created graphics with exactly the same properties, in a kind of deep neon pink. When I bring these in, they look fine in the viewer. However, once added to the time line they become all aliased and jagged, on the non vertical/horizontal lines. I have attached an image to show you exactly what I mean.
    Image here: 0_screenshot2012-09-13at11.32.17.png
    This is not simply a preview issue either, as I have exported out a section with these coloured graphics as APPLE PRO ES 422 (HQ) and the problem remains on the export.
    ANyone have any suggestions? It is puzzling that this doesn’t happen to white graphic elements but only if they are colored. Truly stumped by this one.
    Thanks in Advance
    MATT TAYLOR
    FCP STUDIO 7
    PHOTOSHOP CS4
    APPLE IMAC 3.1 GHZ INTEL CORE I5
    16GB 1333 MHZ DDR3
    Matthew Taylor replied 13 years, 11 months ago 3 Members · 3 Replies
  • Rafael Amador
    September 13, 2012 at 12:25 pm
    Have you checked the Alpha channel (browser)?
    rafael
    http://www.nagavideo.com
  • Joe Barta iv
    September 13, 2012 at 1:44 pm
    Check in the Motion tab in the viewer to see if it is Scaling the image up or down in size.
    Bars & Tone
    SALUTE!
  • Matthew Taylor
    September 17, 2012 at 7:20 pm
    Hello Joe and Rafael
    Sorry I didn’t come back thank you for your help sooner. Unfortunately your advice still left me scratching my head. the alpha was set to straight and the image was not scaling up or down. I have however found a SOLUTION, if anyone else runs into this problem.
    On your APPLE PRO RES 422 (HQ) export from COMPRESSOR, in the Video settings, if you tick the ‘Enable Chroma Filtering for 4:4:4 sources’ check box, this seems to display your colour correctly and with smooth edges on your final export.
    Thanks again guys and sorry for the late reply. But I eventually found a solution. Hope it helps someone else along the way.
    Regards
    Matt Taylor
