Activity › Forums › Adobe After Effects › colored layers…
colored layers…
Posted by Chris Balogh on July 13, 2009 at 1:22 pmCouple questions:
How would I be able to take footage, that is of airplanes, get rid of the background, replace it with color, and totally change the color of the airplane as a solid color?
Thanks in advanced.
Mike Park replied 17 years, 1 month ago 5 Members · 9 Replies -
Michael Szalapski
July 13, 2009 at 2:34 pmDepends on the color of the background behind the airplanes in your footage. If it’s footage of an airplane against a cloudless sky you could use keying methods to isolate the plane.
If it’s a busy background behind the airplane in your original footage, like, if the keying doesn’t work, you will need to do rotoscoping.
In either case, you merely need to isolate the plane, then you can put whatever you want behind it and use the plane as a track matte for whatever you want it to look like.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Mike Park
July 13, 2009 at 2:34 pmLet me make sure I understand you. You basically want to take a real video of an airplane, cut it out, color it one solid color, and color everything else another solid color – kind of like clipart.
The ease of this depends on the difference between the colors or luminance of the airplane vs. its surroundings. You will want to key out either the plane or the background. Then, simply create a new solid the color you want and place the keyed footage on top. Use a fill from “effects/generate/fill” on the keyed layer and you have it licked. Easy in concept – may be trickier depending on how well the keying goes.
The other option is rotoscoping, where you will need to manually cut out each frame with masks instead of keying – if there is not enough seperation between the luminance or colors.
Best of luck
Erik Waluska
July 13, 2009 at 2:35 pmRotoscoping or keying the footage. Which one to use depends on the footage and the background.
Erik Waluska
July 13, 2009 at 2:39 pmWhoa, that was weird! All three of us posted within seconds of each other with the same basic answer. Jinx!
Mike Park
July 13, 2009 at 2:57 pmThat happens when it is the correct answer. Now if we had 3 different, mutually exclusive ideas…
Alan Lloyd
July 13, 2009 at 3:37 pm“Now if we had 3 different, mutually exclusive ideas…”
…then you’d be economists.
Chris Balogh
July 13, 2009 at 4:05 pmThank you all for the same answers…lol. Are you all in the same room…weird. Anways I thought that and was making sure…could i even try a longer process of cutting the objects out in photoshop by rendering a film strip through premiere to be real precise?
Michael Szalapski
July 13, 2009 at 4:34 pmRotoscoping in AE can be pretty precise, but yes; you can do it in Photoshop too.
– The Great Szalam
