Activity › Forums › Apple Final Cut Pro Legacy › Color/brightness changes when superimposing titles.
  • Color/brightness changes when superimposing titles.
    Posted by Lars Apneseth on January 3, 2007 at 8:58 am
    Hello.
    The color of my clips are slightly tinted (into a greenish tone) when I put at text on top of them in the timeline. The color returns to normal when the text fades. The brightness also seems to change, but only as a tiny flash during the in/out transitions of the text layer.
    Any recommendations?
    Thanks and regards.
    Tocha replied 19 years, 8 months ago 3 Members · 2 Replies
  • David Roth weiss
    January 3, 2007 at 6:52 pm
    That certainly should not be happening, and does not happen on any FCP systems I work on. Which test tool are you using? And, what render settings are enabled on your system?
  • Tocha
    January 7, 2007 at 11:42 pm
    Hi
    Try this:
    Sequence settings > Video processing
    and chose render in 8-bit YUV
