Activity › Forums › DaVinci Resolve › Color trace seems to not work with ACES in Resolve 11.3
  • Color trace seems to not work with ACES in Resolve 11.3
    Posted by Mike Most on April 19, 2015 at 1:31 am
    Running color trace in an ACES 1.0 project in Resolve 11.3, the expected Color Trace dialog comes up, the sources are all found and matched, and the grades seem to be applied. However, no actual values come across on any nodes. If I try the identical material, sources, and conform timeline using normal DaVinci YRGB everything works. The only way to get it to work was by using a combination of the two, setting up the destination project as YRGB, doing the color trace, then changing it to ACES. Even this method took a bit of doing (I had to color trace to another YRGB project first, then color trace from the ACES source project). Is this a known bug/limitation of working in ACES at the moment?
    Mike Most replied 11 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
