Activity › Forums › Apple Final Cut Pro Legacy › Color to Final Cut
Color to Final Cut
Posted by Jose Arce on June 14, 2009 at 3:36 amHi,when I work the color correction in Color an later I send the final render to final cut I have problems to play in real time the sequence from color.I have a MacPro with 6 Gb Ram, and two 2.6 ghz Intel Processors.
ThanksJose Arce replied 17 years, 2 months ago 3 Members · 6 Replies -
Rafael Amador
June 14, 2009 at 1:30 pmHi Jose,
Which codec are you using on exporting?
Color by default render to the Color Documents folder, in the main HD, no the best place to play nothing from.
rafael -
Walter Biscardi
June 14, 2009 at 5:17 pm[Jose Arce] “Hi,when I work the color correction in Color an later I send the final render to final cut I have problems to play in real time the sequence from color.”
Your Render folder in Color is probably set to the internal HD instead of your media array.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Jose Arce
June 14, 2009 at 7:03 pmHi, I use the 10 bpc uncompressed, I set the render folder outside to the HD disk, in a external HD.
Walter Biscardi
June 14, 2009 at 7:26 pm[Jose Arce] “Hi, I use the 10 bpc uncompressed, I set the render folder outside to the HD disk, in a external HD.”
What type of array are you using?
For Standard Def you’ll want around 50MB/s for 10bit uncompressed SD playback.
For High Def you’ll want around 250 to 300MB/s for 10bit uncompressed HD playback.
Rafael Amador
June 15, 2009 at 5:26 pm[walter biscardi] ”
What type of array are you using?For Standard Def you’ll want around 50MB/s for 10bit uncompressed SD playback.
Right.
You really need fast raids for 1920×1080 HD 10b Unc.
You may try Proress it moves much more easy.
rafael -
Jose Arce
June 17, 2009 at 3:04 amHi, yes, the Prores is more easy to moves on, but I thing lost a lot information, you know a video in Uncompressed have 50 mbs or more, in Prores have 30 Mbs, but is better. Thanks.
