Activity Forums Adobe After Effects Color Swatch Window, does this functionality exist or is it a feature request?
  • Color Swatch Window, does this functionality exist or is it a feature request?
    Posted by John Cuevas on February 26, 2014 at 1:15 pm
    Different clients have different palettes and I often end up making a pre-comp with all there colors and dropping it into my master comps and make it a guide layer. It would be nice to have a dockable color swatch window like illustrator where I could save/load different clients color palettes, right in AE.
    So is there a way to do this, does it exist as a script somewhere, or is this something I should ask Adobe to put on there to do list?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
    George Goodman replied 12 years, 6 months ago 4 Members · 5 Replies
  • Walter Soyka
    February 26, 2014 at 1:23 pm
    You have a couple script options:
    https://aescripts.com/chameleon/
    https://aescripts.com/colorlibrary/
    But this is also a good feature request nonetheless.
    Walter Soyka
  • Walter Soyka
    February 26, 2014 at 1:26 pm
    I should add: I often create a composition named Palette with a null layer named Palette, and drag Color Control effects onto it. I open a new, locked effects control panel for Palette:Palette and dock it on the screen, and pickwhip colors to the locked and docked Palette ECP.
    Walter Soyka
  • John Cuevas
    February 26, 2014 at 2:17 pm
    Knew somebody must have engineered a solution to this already. Thanks Walter.
    Thinkck.com
  • Ridley Walker
    February 27, 2014 at 12:27 am
    [Walter Soyka] “I should add: I often create a composition named Palette with a null layer named Palette, and drag Color Control effects onto it. I open a new, locked effects control panel for Palette:Palette and dock it on the screen, and pickwhip colors to the locked and docked Palette ECP.”
    You are a clever man Walter, thanks for the tip.
  • George Goodman
    February 27, 2014 at 3:18 pm
    Genius Walter!
    “|_ (°_0) _|”
    Sincerely,
    George
