Color Space Shift, Soften
We have 720p 60 DVCProHD footage that looks pretty good. A little over exposed and white balance a tad off, but detail is pretty good. On both our Aurora Pipe systems and the Kona 3, if we create a DVCPro50 sequence and bring in the clips, it inevitably softens the footage and has a slight color shoft….seems to add a bit of yellow.
I took the 720p clip into AE and dropped it into a 720 x 480 comp and rendered out a DVCPro50 clip. Maybe a bit less softening, but still can’t nail down the color space. Getting nominal gamma shifting. Tried multiple project color space and clip color management options….same results.
Anyone else bringing 720p 60 footage into standard def sequences or in AE comps and having success retaining full detail and gamma? The softening in FCP between the raw clip in the source window (viewed on either a CRT or an LCD) and the clip in the sequence after scaling down and rendering is quite noticeable and unacceptable. Just can’t find the right combination to keep detail.
We are currently cutting in DVCProHD, which looks same as source in the sequence, however it will eventually end up as a TV spot, letterboxed, but the client was hoping that the extra resolution of the 720p material would allow some scaling of shots in FCP within a letterbox area. We thought so too, but now we are seeing the softening. Also, they have typically gone to a full 4×3 full screen end tag after the letterbox footage, so cutting entirely in 720p and simply letting the deck downconvert to the Beta Station dubs sounds good up until the end frame, and not allowing us to pan and scan around any of the clips under the letterbox in an SD frame.
Thoughts?
BTW, we have looked at this footage on FCP systems with Kona 3 and QT 7.4 as well as a FCP system with no card with QT 7.5.5 and the Aurora Pipe system with FCP 6.0.4 and QT 7.4. Same results on all systems.
My assumption is that FCP is pretty awful at scaling 720p footage in an SD sequence (we tried 10 bit uncompressed etc as well with same results) and AE is still having trouble with gamma when mixing HD clips and rendering out to SD codecs.
Thoughts?
Rich Rubasch
Tilt Media
