Activity › Forums › DaVinci Resolve › Color Space Monitoring and Output Questions?
  • Color Space Monitoring and Output Questions?
    Posted by Jamal Howard on December 27, 2011 at 7:52 pm
    I’m grading a RED project in Resolve and trying to get a full understanding of color/gamma spaces.
    Right now I’m grading from the RAW files using REDColor 2, and REDLogFilm. I’m using a LUT I built from the Arri LUT generator (Log C to Video, Extended Range, Color Space “None (1D)”, Forced 3D LUT).
    I’m monitoring this on a Sony HD CRT broadcast monitor.
    Now here’s where I get a bit confused… is my output suitable for DVD/Blu-ray as is, or do I need to use/add another LUT (Rec709?) onto my output?
    What about encoding for web, do I need another LUT for that as well?
    (And if I do need another LUT, should that go on the end of my node tree (or in the output LUT section)? And what LUT’s do I use?)
    Thanks for any insight
    Andrew Britton replied 12 years, 10 months ago 8 Members · 12 Replies
  • 12 Replies
  • Robert Houllahan
    December 27, 2011 at 8:29 pm
    What Sony CRT and how was it calibrated?
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
    http://www.cinelab.com
    MAHC-PRO 6-Core 3X GTX285 20Tb SAS Wave Panel Panny 11UK SDI Plasma.
  • Robert Houllahan
    December 27, 2011 at 8:31 pm
    Assuming you have a CRT calibrated to Rec709 you do not need to add another output LUT. Are you adding the LogC to 709 to individual clips on the timeline or as an overall?
    -Rob-
    Robert Houllahan
    Director / Colorist
    Cinelab Inc.
  • Jamal Howard
    December 27, 2011 at 9:09 pm
    It’s a Sony PVM L5 CRT. Calabrated using color bars (All I have access to at the moment).
    Right now I’m adding the LUT as a node to individual clips as I have a mix of RED and ProRes footage in this timeline.
    As I mentioned in my earlier post, the LUT I generated on the Arri website has no color conversion on it (1D “none”, not Rec709 3D) as I read recommended by Mike Most in other posts. Is that correct?
  • Joseph Owens
    December 27, 2011 at 10:40 pm
    [Jamal Howard] ” Calabrated [sic] using color bars (All I have access to at the moment).”
    “Sort of lined up” is what you get using color bars as a reference. Calibrated, not so much, and I’d be surprised if a LUT made any difference under these circumstances.
    You’ve been working in 709 all along, and otherwise the whole idea of a LUT is a waste of time and processing cycles. BluRay? fine. Automatic Quicktime gamma conversion in Compressor? Also, pretty much okay.
    Maybe I’ve been at this for too long, but I just don’t “get” this multiple layers of LUTs.
    In a sense, every correction is a LUT. Unless you are traversing media with entirely different primary stimulus emitters, LUTs are not necessary.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Jamal Howard
    December 27, 2011 at 10:46 pm
    Thanks for the thoughts.
    So does that mean I don’t need the Arri LUT to grade/view the REDLogFilm files?
    So just do the grade from the (very) flat REDLogFilm gamma?
    And if that’s the case, why has it been recommended to use a LUT on the REDLogFilm files?
  • Mikhail Puzyrev
    December 28, 2011 at 2:29 pm
    When I grade for tv or DVD destination I never use any log colorspace. Rec 709 colorspace and 709 or redgamma2 gamma curve. Otherwise it’s a waste of time.
  • Omar Godinez
    December 28, 2011 at 5:21 pm
    Joseph,
    You and I have have pretty much the same experience. I agree with you, for me, every correction is a LUT.
    I prefer to start with Alexa LogC or REDlog Film in Node 1 with a Primary Custom LUM S-Curve or an aggressive Primary Contrast correction. That, for me, is my LUT. Then, I go into grading.
    Omar Godinez
    Colour Cafe, LLC
    Dallas, TX
    MacPro5,1 2.93GHz 12-Cores
    24GB RAM
    GTX-470 (x2)
    RED Rocket
    FSI LM-2461W
    BMD UltraScope
    Panasonic 12 Series Pro Plasma
  • Mike Most
    December 28, 2011 at 11:47 pm
    Its not a waste of time if you use it correctly. Using Redlogfilm as the gamma curve allows full retention of virtually all information in the original RAW record. If you use a proper processing pipeline, it also yields what is arguably the best greyscale interpretation of Red material that has ever been available, superior to and more controllable than either Redgamma or Redgamma2. How to do that most effectively has already been discussed in numerous threads here and elsewhere.
  • Nook Kim
    December 30, 2011 at 8:08 am
    I think Jamal is also asking about using LUT for previewing in another color space (or gamut, sRGB in this case) than the primary delivery format (Rec 709 in this case). IMHO, this is very important practice to have extra preview monitor(s) for different color spaces unless I’m allowed or paid to perform multiple rounds of grading just for any additional delivery formats.
    Just for this purpose, our team is preparing a color management pipeline which includes top-of-the-line hardware and softwares. Our aim is to be able to match all in-house monitors as close as possible and to generate and utilize color space conversion LUT’s.
    As for the use of LUT in Resolve for Red material, I also grade in Redcolor2/Redlogfilm with Arri Log to Rec709 3D LUT as input LUT at the project level. It is no doubt that Redlogfilm offers much more useful range than any other gamma space Red has to offer in grading environment. Very rarely, I do grade without the LUT if I feel like the LUT is limiting the range of the footage. However, I can’t argue with how effective it is to use the LUT since it really speeds me up.
    Nook Kim
    http://www.nookkim.com
  • Mike Most
    December 30, 2011 at 4:57 pm
    You should not be using a LogC to Rec709 LUT as built on the Arri site as that would include an Alexa-specific color matrix. You should build a LUT to go from LogC to Video without the matrix. That yields a great result when used behind Red footage that’s interpreted using either Redcolor or Redcolor2 (those are color matrices) and RedlogFilm. You don’t want to be using another color matrix as that will yield extreme saturation and incorrect colors. Further, you should not be using the LUT as an input LUT as that will limit information, especially if the image is underexposed or overexposed. You should have the LUT downstream in the processing path, at least after an initial correction, to allow for exposure adjustments prior to the LUT. All LUTs are designed to convert from one color space to another based on a proper exposure. If the material is not properly exposed, the LUT cannot do its job. You can fix that limitation by using the LUT after an initial correction, either on the first node, a later node, or on the output.
