Activity Forums Adobe After Effects Color Space Matching
  • Color Space Matching
    Posted by Scott Skaja on February 7, 2009 at 5:21 pm
    I’m working with DVCProHD files in AE. I made Comps using the same specs. After working on, rendering and importing the files into Final Cut, the gamma/contrast do not match to what I saw in After Effects. I’ve tried enabling/disabling the Final Cut Gamma Correction check box in Quicktime preferences, but I came away with the same result.
    Can anyone help me understand what it is I’m not doing correctly?
    Scott Skaja
    edit/design/animation
    http://www.scottskaja.com
    Mohamed Selim replied 17 years, 6 months ago 2 Members · 1 Reply
  • Mohamed Selim
    March 17, 2009 at 4:32 am
    Try going to final cut pro preferences then editing tab, and limit the gamma to 1.8 as a custom setting, then re import your files again and compare, hope it works for you.
