Activity Forums Maxon Cinema 4D color space issues
  • color space issues
    Posted by Quico Encinias on May 25, 2011 at 11:02 pm
    I set up a Net render with 7 OSx computers. 4 of them are rendering slightly lighter than the other 3. I am running client 12.0.16 which is the latest version. All the clients have been transferred from the same folder.
    I have narrowed it down to the Project Settings “Input Color Profile”. If i use linear or srgb i get color and luminance shifts between computers. But if i set it to disabled, then it renders fine.
    I have set the output files to try srgb and linear and No color management and those render the same across computers.
    It seems it is only changing things on the texture input.
    Where is cinema getting its information to interpret my texture images?
    If i know then i can compare profiles from the different computers.
    anyone else have this problem?
    Quico Encinias replied 15 years, 3 months ago 1 Member · 1 Reply
  • Quico Encinias
    May 26, 2011 at 12:53 am
    So i believe that it is due to a quicktime issue. I tested all the textures and the stills are fine. It is a quicktime movie thats being used as a texture that is changing. When i compared the different computers, we have a split between versions of quicktime. I will upgrade them all and see what happens.
