Activity › Forums › Adobe Premiere Pro › Color Space 4:2:0
  • Shane Ross
    September 24, 2019 at 12:13 am
    Color space is typically tied to a codec. ProRes 422 can only be 4:2:2…thus why it is called ProRes “422.” HDV is a format that can go 4:2:0…as are a few formats of H.264…and XDCAM. So…when they say they need it to be 4:2:0…what CODEC do they also want it to be? Only certain codecs can be 4:2;0. I’d think the codec type was more important than the color space.
    Shane
    Little Frog Post
  • Pat Horridge
    September 24, 2019 at 7:19 am
    Work in 4:2:2 and output in 4:2:2 as a master file.
    Then convert that to the required codec that will allow you 4:2:0 colour subsampling
    Pat Horridge
    Broadcast & Post Consultant, Trainer, Avid Certified Instructor
    Free online Tutorials at VET digital media academy online https://vimeo.com/channels/752951
    pat@vet.co.uk
  • Jeff Kelley
    October 7, 2019 at 7:30 pm
    Thanks so much!
    So the guidelines I was sent had this CODEC (as well as specifying 4:2:0)
    • Video codec shall be H.264/AVC
    Should I assume that will be the right color space?
    http://www.willinois.com
