Activity Forums Apple Final Cut Pro Legacy Color Smooth Natress for Green Screen
  • Color Smooth Natress for Green Screen
    Posted by Josh Thomson on June 8, 2010 at 12:52 am
    Hi there, I am living in a PAL country and have always had issues with the jagged edges from DV greenscreening
    I recently searched and found that FCP’s Color smoothing greatly reduced this jagged edge – even though it only has 411 and 422, not pal 420
    I also recently tried Natress’s G Nicer, which seems to do a similar job with its 420 setting
    Just wanted to know –
    Is the G Nicer filter the same as his Chroma Smoother 420?
    And is the Chroma smoother only for Apple’s Color?
    cheers
    Josh Thomson replied 15 years, 10 months ago 3 Members · 3 Replies
  • Michael Gissing
    June 8, 2010 at 1:14 am
    [Josh Thomson] “Just wanted to know –
    cheers”
    I am sure you can find out by visiting the Nattress web site
    https://www.nattress.com/Products/products.htm
  • Rafael Amador
    June 8, 2010 at 1:37 am
    Hi Josh,
    Nicer works only for 411.
    The Nattress filter you need is “Chroma Smooth/Sharpen”.
    Works for 411/420 and 422.
    It comes in the “Nattress Film effects” pack.
    rafael
    http://www.nagavideo.com
  • Josh Thomson
    October 21, 2010 at 1:46 am
    Thank you so much for your help.
    Much, much appreciated.
