Activity Forums Apple Final Cut Pro Legacy color shifts using quicktime conversion
  • color shifts using quicktime conversion
    Posted by Oscar Postma on December 10, 2009 at 2:33 pm
    Hi everyone.
    I have noticed that exporting from fcp, using quicktime-conversion, even using the same codec ( from prores to prores) leeds to a darker picture. One should expect it to be the same, but thats not the case.
    This also goes for converting it to a different codec. Exporting h246 to prores using qtconversion gets realy dark.
    exporting from the timeline with adjusted setings ( eg a h264 clip on a prores timeline) doesn’t give this color-shift
    Is this a typical problem for fcp 7 or is it snowleopard related.
    Does anyone have encounter the same problem and more important, did someone allready find a solution, because using qtconversion is not really a goed option at this time.
    Further more in doing some experiments importing uncompressed quicktimes ( uncompressed 8bit-blackmagic codec) from Filmmaster( digital vision) to fcp resultes in a strange greenish colorshift and it gets a bit washed out ( gamma shift???)
    Can someone tell me if there is a workaround for this problem, or is filebased in-and exporting from fcp not done ;-(
    hope to here from you
    manny thanx
    oscar
    Rafael Amador replied 16 years, 8 months ago 2 Members · 1 Reply
  • Rafael Amador
    December 10, 2009 at 4:12 pm
    Hi Oscar,
    Normally the people around use (if they do it) for non critical exports, or for audio, Still sequences, etc.
    Better avoid it unless you have a good reason to use this way.
    Cheers,
    rafael
    http://www.nagavideo.com
